Definitely the VP Free over the V-10!
turboox said:
Thanks for all the input. I think I've decided on the Free over the Bullit. However, I just found a great deal on a v10(classic). Now I've got to decide a dedicated DH or a FR/DH rig. I suppose the 10" of travel on the v10 should be able to soak up and drops or stunts but may be too much bike to pedal when flat or uphill.
Anyone with any experience/thoughts they care to share?
Hi turboox,
I have over 60 days on the VP Free over the last two seasons and only one day on a V-10 but to me there is no question on the right answer if you need to pedal on the flats much less pedal uphill! The following is from a thread on the SC forum that covers this issue in detail:
"Perhaps, (and this goes to the heart of your question), because the v10 has almost 10" of travel, and about 4" of normal sag, they set the bike up this way to have optimum geometry when sagged. I notice the bb is also listed at 14.8", which is high until you actually sag the bike, at which time it becomes a DH race bike. The sag is really (all other things being equal), what kills you when climbing, I think. Nothing worse than wallowing around inside 4-5" of travel both positive and negative, it really saps your power.
The bike is not meant to go uphill, head angle aside. It is a heavy frame, designed for a 150mm rear spacing, (heavy), and is in general, not designed to pedal up hill. You of course "could" pedal anything uphill if you are strong enough, its not like it "can't" pedal uphill, but why would you want to when there are so many other frames out there that do that better?"
Here is the entire thread:
http://forums.mtbr.com/showthread.php?t=484269
In fact I believe the Bullit would be superior to the V-10 when it comes to pedaling uphill. I'm sure others with more experience on the Bullit and the V-10 will be able to answer this question better that I.
Good Luck,
Michael:thumbsup:
