1 - 10 of 10 Posts
EDR
I say buy a 5 degree stem that you like then sell the Thomson. You'll have the stem you are comfortable with and probably 50 bucks in your pocket :)
FWIW I use the 10 degree x4. I can't imagine liking a zero degree stem, I like to have the bars level or a bit higher than my seat.
First, find seat height...
Like EDR said, most like their bars level or a little above level. I have the top of my grips about an inch higher than my seat. But, thanks to my short-ass legs, I have to use a 0 degree stem, low rise bar, and one thin (1/8 ") spacer under my stem in order to make this work.
Your saddle height and it's fore/aft position is the 'constant' to the equation. My saddle is always at the exact same spot, so after that it's just a matter of fine tuning the stem height and length to get your bars where you want them.
provided you have enought steer tube to work with, spacer stack height and handlebar rise give you enough adjustment that you can use either the 10 or 0 and get your hands where you want them.
Discussion Starter · #6 ·
Thanks, yeah i've got plenty steer tube to work with - had it cut long for this reason.
I've ordered the 10 - if I don't like it the place i'm buying from said I can change it for a 0
or a different make altogether.
Cheers
Surf 'n' Trail Rat
My own personal preference is for more of an XC positioning (even tho I ride 'all-mountain').
I use a Thomson 0 degree 100mm with low rise Easton EA 70 handlebar, and i'm using one 3/8" spacer between the HS and stem.
local trails rider
Whatever gets your hands where you want them...
I just installed a 10deg Thomson 4x 90mm on my new non-Yeti HT, inverted, to get my bar where I want it.
1 - 10 of 10 Posts
