shouldn't be any different then any other bike. You will want a long if you are running triple rings up front. you can only use a short cage if you are running 2 chain rings up front and then only if you stick to 32-22.dulyebr said:I'm getting a SRAM X0 rear deraileur for my new ML, what size do they take, long or medium cage?
thanks
You don't need a long-cage for a triple. You shouldn't run more than 2 chainrings on a short-cage RD (like a road derailer), but you can run a medium-cage X.0 on a 3-ring setup. You just have to be more careful not to cross-chain. Check the drivetrain forum for many threads on this topic with pros/cons of each side. I personally prefer a medium-cage derailer for crisper shifting and more ground clearance and I've never had a problem with a standard 22-32-44 chainring and 11-32 cassette combo. YMMV.demo_slug said:shouldn't be any different then any other bike. You will want a long if you are running triple rings up front. you can only use a short cage if you are running 2 chain rings up front and then only if you stick to 32-22.
