Hello!
I'm planning to order the DT Swiss Competition 2.0/1.8 but cannot figure out the size: 288 / 290 / 292 / 294 / 296 / 298 ?
I'm so confused trying to use either the dtswiss spoke calculator or the spocalc.
I get different values in either !!!
I'm trying to build a 700 x 28 wheel (32 holes) to convert my XC to an urban bike.
Can you please help me out in finding the right size of spokes, if I supply some info and values about the parts I'll be using?
(The weight and the dimensions are from the Shimano's tech documents.)
Rim: Mavic Open Pro (Black)
Front hub: Shimano Deore XT HB-M756
Rear hub: Shimano Deore XT FH-M756
Total number of spokes: 32
3-cross
Thanks for any help in advance.
ERD (Effective Rim Diameter): 605 mm (spocalc) / 604 mm (dtswiss calculator)
Weight: 435 g (dtswiss calculator)
Weight: 244 g
Flange diameter: 61 mm
Over lock nut dimension: 100 mm
Center to flange (left): 35,8 mm
Center to flange (right): 35,8 mm
Weight: 435 g
Over lock nut dimension: 135 mm
Center to flange (left): 32,15 mm
Center to flange (right): 18,55 mm
3-cross
