1 - 5 of 5 Posts
· Registered
Hoping to set up some drivetrain options for the bike I have on order. (1x10 and quick change to 2x10) I'm not sure the Cannondale tech docs are up to date.
It will come w/ the spider for XX rings. (26,39) 80mm-120mm BCD.
What other spiders are available? Triple vs. Double, 4 bolt vs 5 bolt, BCD?
Hoping for a comprehensive list so I can hash out my options. But I'm hoping for a 4x104mm triple, to set up the 1x10 with a chain guard and centered chainline.
· FIRENZE rulez !!
you wrote for 1 x 10
i did it with a 110mm BCD spider , compact road spider and a 36T oval rings from Rotor Spain ciclocross ring, mounted internally
can do it with a 130mm road spider too ... limit is the ring teeth size only :p
however also there are :
5 arms 94mm BDC spider , double 40 up to 44 as big ring , 29T as minimum as little ring
5 arms 94 -58 mm BCD spider , triple or can be used as double using a 20T as minimun as little ring . very rare , older triple standard until 2003-2004
4 arms 104-64 mm BCD spider , triple or can be used as double
4 arms 120-80 mm BCD spider , XX rings only , 25T as minimum as little
obviously i have at least one piece of every type :D
· Registered
Discussion Starter · #4 ·
Thanks Eliflap.
I'll likely go with the 5 arm compact road or the 4 arm 104mm triple. Depends on chainring availability.
N'Gear jump stop on the inside & Spot Brand chain guard in place of the big ring.
Thanks again.
· FIRENZE rulez !!
please consider this point too:
spiders has different offsets ( i not wrote in previous message but for 94mm double there are 2 versions , for 68 or 73mm BB shells ) and frames has differents chainstays width too...
so sometimes you cannot have a successfully set up as you want...
for example :
Scalpel carbon with 4 arms 104-64 mm spider , modified as double .
max bigger ring in middle position is 38 or 39T ( sorry not remember well, maybe Kayba can helps you well in this point )
installing a 40T or bigger , you hit the chainstays ...
consider a no spider combo ... here in Italy at least 4 companies produce that type of combo as picture ... installing only the bigger ring for 1 x 10 with a shoter spindle for correct chainline maybe can be another way to have your set up
1 - 5 of 5 Posts
