Bike will be this: RADON BikesZR Race 8.0
Fork is this: SID RL | SRAM
Axle to crown length of that fork is 473mm and spring travel is 100mm. I've been told rigid fork's a-c should be 445mm, is that correct?
It seems that the brakes are PS mounted so I need a fork with PS mount or can I use IS mount fork if I'll use an PS -> IS adapter?
445mm PS mount Carbon fork option examples:
DT Swiss - XRR 445 - 240€ / 585g
eXotic Carbon - 130€ / 780g
eXotic Carbon Tapered - 170€ / 860g
445mm IS mount Carbon fork option examples:
eXotic Carbo - 130€ / 760g
eXotic Carbon - 190€ / 740g
445mm IS mount Alu fork option example:
eXotic Alu - 100€ / 900g
It seems that all Carbon forks have around 95kg limit for rider weight and Alu forks have no limits. For some reason Alu forks feel stronger and safer. The eXotic Alu fork also looks better than the Carbon forks since Alu version is matte black. Not big difference in weights expect the DT Swiss which is almost half the weight of the eXotic Alu, but then again it's also over twice the price and has that 95kg rider limit.
So as for now I would prefer Alu forks. The eXotic Alu would need a IS to PS adapter though. Don't know if that setup would give any problems.
What would be the way to go?
