1 - 20 of 28 Posts
That is an '89 ClimbMax. The TBG sticker & the P2 fork tell all...
Late '89 Brodie switched from Tange MTB to Prestige.
The stem is a Nitto. It was a standard with the build kit which came with that bike.
Discussion Starter · #7 ·
Thanks Stig and Umma! I have never even seen a Brodie in person before. Looks like a pretty decent bike. This one was ridden alot. Too bad one of the bar ends are bent. :(
Wow! Ridden a lot and maybe by me. I had a couple like this and that looks like one of them, with some parts changed out. Want to sell it back?
Oh, and someone else covered off the details. 1989 Brodie ClimbMax. Serial number in the 4000s, if I recall correctly.
Same question: I have a Brodie from around the same era. What model is it?
Details, when I bought it 4 years ago: Full first "rapid fire" generation XT. XTII U-brake. Gatorblade fork. Kona-style stem (very similar to a Joe Murray Velocity). "Art department" paint. No serial number that I can find. No seat tube collar / reinforcement. TIG'd front triangle / brazed rear triangle. Ovalized top, down, and seat tubes (need to check). Most of the decals were worn off when I got it, but it had a custom Brodie "concept" tubing decal on the seat tube. Or something like that.
I've replaced pretty much everything on it with m900, added drop bars, and now use it as an off-road touring bike. The paint was in rough shape when I got it, and I'm debating sending it to Joe Bell or Chris Dekerf... just need to settle on a color. Does anyone have any suggestions re. painting the gatorblade fork? Does it need to be taken apart?
</a>
More photos.
....Ovalized top, down, and seat tubes (need to check). Most of the decals were worn off when I got it, but it had a custom Brodie "concept" tubing decal on the seat tube. Or something like that.
If all tubes are ovalized it was probably made of tange concept tubing, so it is probably a catalyst. Serial number should be on the BB shell.
As for painting the fork, a good painter should be able to mask the crown and do a good paint job on it.
Gatorblades........
just put some gatorblades on the soverign.........could be sweet........needsome moe parts to get her up and running........
ud
Hi,
Very nice bike. Brodies are very desirable to me.
On the stem: I see some resemblance with a Tioga Mountaineer (by Nitto) I have. Same shaft & also black chrome.
Different is that the that cable works with a pulley vs internal routing, there is another bar clamp ...and of course the one on the Brodie is fillet brazed, what is another nice touch.
Those are nice stems.
FreeRider 4 Real (not!)
So early Konas was called TBG also, is early Brodie and Kona the same brand?
surlytman said:
TBG was a distributer. The Bicycle Group.
TBG distributed Kona, Brodie and even Merlin (for one year). Joe Murray et al actually raced Brodies, but they were sometimes disguised as Konas. Actually, the 1990 TBG/Kona catalogue shows Kona-jerseyed riders on Brodies. See it here.
1 - 20 of 28 Posts
