1 - 16 of 16 Posts
· steel is real...heavy
I have an unbuilt NRS frame that is begging to be completed. I am having a helluva time trying to find a 6.5" shock for the rear.
The ones on ebay only seem to have an air valve for rebound, is it necessary to have a negative chamber to correctly setup the suspension? Does it need to be a shock WithOUT SPV or propedal?
Anyone know where I can get the right one without having to spend more than $100?
· bi-winning
Cane creek makes shocks that will fit. I know many use the cloud nine model, but that could likely fall above your budget. Try looking at the AD models as well.
SPV is not really something you want, as the NRS has no use for it. Any propedal/SPV will only make the ride more harsh.
I believe that the NRS is supposed to have a fixed negative air pressure. This can be done with the sid shock that was standard for many years. The Float on my 2005 is "NRS tuned" but i doubt you would be able to get your hands one one of them.
· [paste title here]
Yeah try the Cane Creek shocks. I think they make a AD-12 or Cloud Nine that fits. Supposedly it makes the bike a bit plusher, but I have never tried it. Ive been wanting to upgrade, but I havent had the time. CC also offers a shock trade-in program where I think they'll give you about 100 bucks off a new shock.
· Registered
The best way to go is Cane Creek Cloud Nine, that's what I have on my NRS. it makes the ride a lot better compared to the old Rock Shox, also it has a Rebound Compression Adjust Button that acts some what of a lockout. and a big plus for this shock is you can rebuild it your self it only takes 10 minutes of your time and $20 for a seal kit.
· I'll rest later
I'm seriously considering purchasing a Cloud Nine for my NRS to replace my old Rock Shox SID. Having never replaced a shock I'm confused about whether I need any extra mounting hardware. Can I just use the hardware which was used for the Rock Shox or does the mounting hardware I need come with the Cloud Nine? Do I need to order mounting hardware separately?
Steve
· Registered
Steve
I use the mounting hardware that came with the Rock Shox SID. and it works perfect!
· bi-winning
robdamanii said:
Another question on the Cloud 9. Does it have the adjustable negative chamber or does it perform ok without that?
http://canecreek.com/cloud_nine.html
nope, negative spring is not adjustable. Apparently, it rides great without it.
For the SID shocks, giant reccomended a fixed pressure in the negative spring anyways, although some used it for fine tuning.
1 - 16 of 16 Posts
