1 - 9 of 9 Posts
alright, so i have looked and cannot find the answer.
background - i just picked up a used niterider battery pack. it didn't hold a charge right away so i am cycling it a few times to see if that helps. if not, i will have to either have it rebuilt or rebuilt it myself. i have done this for drill and R/C batteries, but they only used 2 wires.
so i am trying to figure out why there is a 3rd wire before i begin to deconstruct it. anyone know what it is for? are there any diagrams out there?
thanks
Discussion Starter · #4 ·
i took apart a different pack (waterbottle pack) and found that it had two wires only. so i guess it is not necessary to have a useful pack.
thanks for the info.
Do It Yourself
As MtbMacgyver said, it's not always used. However, that doesn't mean it's not important. Temperature (ΔT) is the best charge termination method for nickle based batteries so I would try to reuse the themistor and keep the third wire if you can.
Discussion Starter · #7 ·
if by charge termination you mean the charger knowing when to shut off, i am not sure that is accurate. i always understood peak voltage to be the measurement of choice. i have a peak voltage charger that i like to use. i am considering making a plug adapter to use that on these batteries.
also, with that charger, i can use a higher charge rate which would mean less time on the charger.
Peak voltage detection is what most chargers use, because it's cheapest. But delta temperature is the most reliable termination method and is supported by most high end chargers.
Higher charge rate does mean less time on the charger, but the trade-off is shorter battery lifetime.
Discussion Starter · #9 ·
interesting. i thought you wanted to match the charge rate to the capacity of the battery? 2500mah = 2.5 amp charge rate. 5000mah = 5.0 charge rate.
the chargers that came with the batteries are 2.0 or the fast chargers are 2.5. but the batteries have a higher capacity than 2500mah. is that inaccurate?
edit
it doesn't really matter. just remembered my battery charger only charges up to 7 cell pack.
1 - 9 of 9 Posts
