What is thru axle. I understand quick release as my judy tt forks use this. So i am aware of what a hub is like with no fork on etc.
Would it be that the forks dropouts are closed circles and that to remove them you would have to undo a nut at each side and then slide the axle totally out from the hub and through one side of the fork or am i way off.
Thanks in advance.
also, what advantage is this to quick release apart from things like anti theft (of your wheel)
Thanks in advance.
