1 - 20 of 22 Posts
Ooh, something;s coming back! I wonder if it'll be a 29er or the good ol' 26" steel HT??
I predict a 120mm up front, steel frame with a 142x12 rear.
It's about time!
I have been riding a fat bike for the past 2 winters and I now hate to see winter end. In fact I love big tires so much I sold my FS mtb frame and fork and built a 29+ for my summer ride. Love the traction and stability. I am climbing stuff I have no business climbing and I am so much faster.
Any bike with a tire smaller than 3" is a road bike:p
Doesntplaywellwithmorons!
I called that happening months ago... I knew something was up when my post got 250+ views but no response from RMB who usually has someone reply on question threads eventually.
As to Rockshox... take the RS-1... widen the crown/upper carbon and poof...fat fork. Its tall enough already and uses QR15 dropouts with 110mm spacing currently. Nobody on a fat bike is gonna notice a bit of loss in torsional stiffness from not having the torque-tube hub when you add an inch to the dropout spacing and combine it with tires around 6 psi of air pressure.
I said they would bring back the Blizzard as a fat bike a year or two ago. It just makes sense. Glad they did it. Now they just need to make one in carbon with a carbon rigid fork, rims and the new Next crank. Carbon everything. :)
35lbs is not heavy for a fat bike considering some Surlys are around the 40lbs mark. And for the intended use, 35 lbs isn't much either. Of course a 35 lbs weight is hypothetical based on a all-steel hypothesis. House of cards anyone?
Sent from my Lumia 920 using Board Express
I'm saying 25 pounds is too heavy for ME. 35 pounds would be insane. There is no way I'd ever buy a steel Surly or any steel bike ( road, cross, etc). I'm done with steel.
I would have preferred a carbon Blizzard fat bike with all carbon everything but that's not how things work. If this bike sells (and it will) then maybe in 2016 there will be a carbon Vertex/whatever fatbike that weighs under 25 pounds even with the suspension fork.
1 - 20 of 22 Posts
