1 - 20 of 32 Posts
Hi all,
Simple question... what is the best rigid fork going around at the moment?
I am looking for bomb proof, ~490mm AC height, lightish and good value.
I have a Maxlight XI QR at the moment but there's very little clearance to the brake rotor and it catches some times which is a little disconcerting. Otherwise it is a pretty decent fork and it seemed to do a lot of the Tour Divide folk just fine.
Anyway...
Niner Carbon? Low AC height, not much tyre clearance and seem a touch fragile. Well the internetz has some broken ones so that's a big mental hurdle
Cheapy far east copies? Not winning me over on the durability front even if it is only mental
Salsa Firestarter Carbon? Seems to tick all the boxes but isn't cheap
3T MTN? Pretty cheap in the UK, 500mm AC height but a bit of an unknown quantity
ENVE? One of the few with reviews and all seem positive but not cheap, AC height is a bit low and it looks odd without the fender which I'd leave off.
Something steel? Most seem to either be twangy or dead, not light and seems hard to find something high quality. Singular would be the one at the top of my list but low AC and I don't think they sell them anymore.
Top of the pile for me seems to be the Whisky No.9 bolt thru. Not crazy cheap but ticks all other boxes. The other thing holding me back is no reviews or long term durability feedback. Does anyone use these?
Thanks in advance, DanW
I don't have any experience with the forks you listed. I've used a couple steel forks in the past that worked fine. Currently I'm using an MRP Rock Solid. I have nothing to complain about regarding the MRP. I'd definitely add it to your list to consider.
I haven't used any of the forks mentioned above, but rode the mrp rock solid for 3 years. Great fork. Best, who knows, but it got the job done. It was bomb proof. I never thought twice about anything I hit.
I rode with a Carver XC 490 for a couple of seasons and really liked it. Very bomb proof fork that held up to AM riding with a rigid bike (some of my DH PR's around here were set with that fork).
I'm currently on a Trek 1120 fork, because it is 510 A-C. So far it's been good, but I've only got a handful of rides on it and can't speak to durability.
All of them feel like rigid forks so I don't put much stock in 'ride quality'.
Wanna ride bikes?
I have the Whisky No. 9 carbon MTB fork on my SS. Great fork. Rides nice, good tire clearance. I'm not gentle on it either, 6'3" 205 lbs, avid rider/racer.
I had a Carver 465 (strait steer, QR) fork on my old SS, that was pretty good too. I think the Carver forks are good as well.
The Niner fork would be high on my list. If you like steel check out the Vassago Odis fork (if it's still available?)
Always in the wrong gear
I’ve done some dumb, dumb **** on my bike with my Whiskey no9 fork mounted, (like Black diamond Sedona trails and South Mountain National trail) and it’s held up. Like waist-high drops to flat.
I even broke a steel frame and the fork lives on.
Whisky9 gets my vote all day. I stuck an adhesive-backed cable guide to the leg to avoid the internal routing clusterflock.
I've got an older 490AC White Brothers (MRP) and it's nice. Really good fore/aft movement takes the sting out of dirt road washboard bumps, chundery stuff, etc.. I like it for touring/mixed terrain stuff.
I've also got a Waltworks fork from when I got a frame built by him. It's solid. Stiffer, I don't think about it when trail riding harder stuff. Walt can build you pretty much anything.
Max-a-mill is right about carbon, it's magic for rigid forks.
The Whiskey looks like a good fork. I've been using Niner forks on my two rigid bikes, I really like them. Like Impetus with the Whiskey, I've run the Niners really hard and they are holding up really well. When they need to be replaced, I'll likely be going with Niner again. BTW, They can run up to 3.0, the same as the Whiskey.
Hope that helps
Discussion Starter · #14 ·
Thanks all for the extra thoughts and sorry for the delayed reply.
MRP Rock Solid is a good one I forgot and lots of brands use this design. I used to have an Exotic of the same design and it worked well enough. Not the nicest ride but does the job.
I looked in to the Exotics again but their updated design is the same as the Maxlight I have which I get rotor rub on the fork :( Ditto the updated Carver is the same design.
I ride rigid SS exclusively so have spent a fair bit of time on different designs and can't agree with those who say all rigid forks are the same "feel"-wise. I didn't mention ride quality in my OP but some are definitely more pleasant than others.
Thanks for the other suggestions like Vassago/ Walworks. Being in the UK means a lot of the nice forks that appear here on MTBR are very hard to get hold of or at least work out very expensive by the time they land.
I've checked out Whisky again here in the UK and the bolt thru version is £425 cheapest! They used to be ~£300 which is still a lot of money but not £400+! Really encouraging reviews from the guys who run them though so thank you for that :thumbsup:
Back to the drawing board a little bit I think to try and find something better value than Whisky :(
Discussion Starter · #16 ·
I had completely written off the Niner for low AC height and little tyre clearance. The new ones seem to be listed at 490mm AC height and the updates look much needed. Still Whisky money however :(
Wanna ride bikes?
Well to be fair you asked for the "best" rigid fork, not the cheapest.
I didn't want to post this in the "best" fork thread, but if your willing to lower your standards it seems to get good reviews.
Tandell 29+ Carbon Rigid Fork
https://forums.mtbr.com/26-27-5-29-plus-bikes/tandell-rigid-fork-1074310.html
Discussion Starter · #18 ·
Best in inverted comments as value is part of that and I didn't have a money no object fork in mind, more the best overall fork taking everything in to account. Really my priority is being fit and forget with large mileage rigid SS.
I know a lot of it is in the mind but it is hard to not love a(n annecdotal) review like this :D
I've done some dumb, dumb **** on my bike with my Whiskey no9 forkmounted, (like Black diamond Sedona trails and South Mountain National trail) and it's held up. Like waist-high drops to flat.
Tandell seems interesting, thanks.
The other UK based one which has just come on to my radar is Travers.
https://www.traversbikes.com/store.html#!/Travers-XC-Prong-Boost-Carbon/p/73904492/category=15761046
Professional Crastinator
If you're talking the Carver Trail 490, it looks like the same fork as the Maxlight at 720g. If you can go with the Carver XC490, which is 80g heavier, I can recommend it. I have a Carver Popeye for my fatbike (same design) and it is my go-to fork. I like it better than the Bluto.
-F
I have a Niner rdo boost on my primary bike and have used an enve on a couple bikes and it's currently on my backup bike.
No issues with either. Both have good ride quality with just enough give to smooth things out but not cause issues under heavy braking. No problems with stiffness in corners either.
If I had to choose, I'd simply pick the one with the length that better matched my frame.
1 - 20 of 32 Posts
