I was looking for a tire that is light weight, in the 400 maybe 300 range, that is durable. II don't want to be changing tires too quickly. I need something that can ride well on hardpack, loose gravel, dry stuff basically. Help is appreciated.
Let's see... 300-400g, durable, good on hardpack and gravel...b12yan88 said:I was looking for a tire that is light weight, in the 400 maybe 300 range, that is durable. II don't want to be changing tires too quickly. I need something that can ride well on hardpack, loose gravel, dry stuff basically. Help is appreciated.
Here are some sub 400g tires. All are designed as race tires (i.e. may only last a couple hundred miles) and mainly for hardpack use and are not the best when the terrain gets loose and/or rough. (all weights claimed)b12yan88 said:Hmm how about a light tire 400,300g that handles well on hardpack and dry stuff, and durability is not an issue.
The Python Air Lite is about 450g and is probably the best "light" tire for hardpack that you will find...b12yan88 said:Hmm how about a light tire 400,300g that handles well on hardpack and dry stuff, and durability is not an issue.
Actual weights are 480-490gdgangi said:The Python Air Lite is about 450g and is probably the best "light" tire for hardpack that you will find...
Light weight tires usually has high tpi counts. The smaller threads used make a thinner, more supple and lighter casing. The main weight loss is because of less rubber - in the casing and the tread - being used, and light rubber compounds than usually wear faster....there is NO such thing as a durable sub-500g tire. It just does not exist because the TPI (thread-per-inch) count has to be minimized to cut down weight...which cuts down the inherent strength and durability of the tire.
Thx...Doug
You know more than I do about tires, so you are probably correct.shiggy©®™ said:Actual weights are 480-490g
So, thinner, lighter casing; thinner rubber and less tread = lighter weight, less durable and more prone to cuts and punctures. The minimal tread also reduces traction on most surfaces.
Read my rant on semi-slicks: http://www.themudzone.com/tire/tire_site_files/rants/semi_slick.html
Afraid you are still misinformed.dgangi said:...The example I was using about TPI differences was for the Python and Panaracer tires.
Python Air Lite = 60tpi
Python Gold Elite = 127tpi (+ 100g)
Panaracer Fire XC 1.8 = 60tpi
Panaracer Fire XC 2.1 = 127tpi
Thx...Doug
