I thought this was the other way around- wire beads are easier to mount, as the kevlar beaded ones are generally 'tighter'.DIRTJUNKIE said:Simple train of thought would be:
Kevlar Bead = Folding
Wire Bead = Non Folding
Kevlar beaded tires are lighter and easier to take on and off the rim due to the easy flexing bead. And they can also be folded into a small ball for easy transport. They are also more expensive but IMO worth the extra coin due to the pros vs. cons between the two types.
No actually in my experience wire beads are much harder to mount than Kevlar. I will only use Kevlar now because of the better qualities they possess, that I mentioned earlier.womble said:I thought this was the other way around- wire beads are easier to mount, as the kevlar beaded ones are generally 'tighter'.
It varies from tyre to tyre, but so far I have found the kevlar to be much easier. They almost drop on.womble said:I thought this was the other way around- wire beads are easier to mount, as the kevlar beaded ones are generally 'tighter'.
"Better" is a subjective term depending on what your requirements are and the type of riding you do. Heavy duty downhill and freeride tires use wire beads for a reason, which is to keep them securely on the rim bead during extreme use. In general that does support your statement about wire bead tires usually being tougher to mount / dismount from the rim.DIRTJUNKIE said:No actually in my experience wire beads are much harder to mount than Kevlar. I will only use Kevlar now because of the better qualities they possess, that I mentioned earlier.
