JMKM said:
Interesting yes, but not bulletproof. It is not a definitive test. I spoke with one of their designers at IB. He asked what the interior dims of the new Salsa rim were. It had been so long I had to shuffle through the dimensions in my head to find it. He was more curious than anything and seeing how QBP distributes them I don't think they would want to rip Salsa off. He told me of this new position and I thought nothing of it. Mostly because I feel what they are trying to do is market the rims they design for 29 inch use. I think it makes sense for marketing, but not as a definitive. What they should say is "We think rims with an interior dimension of over x make a 29er tire feel more stable at lower pressures." That is how I fell about it. When you are running 25-30 lbs. in a 2.3 on a narrow rim it feels a little squirmish, I'm sure you could attest to that Shiggy. That is precisely why we designed the new Salsa rim. At low pressures the tire feels stable and solid. That is also why WTB is making some wider rims this year as well.
I mostly agree with you. It is great that wider 700c rims are becoming available.
A tire can be more stable on a wider rim though it does depend on the tire (tread design) and rim. I have always liked the feel of a wide tire on narrowish rims, especially if the edge tread is tall. A tire with a square profile can have great drive/braking grip. They can also be harder to turn and may not track well. I also find them to feel "edgey" when cornering.
On a narrower rim the same tire has a bit more crown. Tracks straighter for me while turning easier. The rounder profile makes for a smoother transition onto the edge knobs, gives me better feedback and feels more solid to me.
I have run 26x2.6 tires (Fisher BearTrax) on Matix Mt Aero rims (19mm outside) at 18 psi without them being squirmy in the corners. I use the Spec Fast Trak 29x2.00 (casing about the same size as the Exi 2.3) on 22mm (outside) rims @ 32 psi.
This applies mainly to XC/trail riding. No big drops, little jumping. Big tires and wide rims are a better choice for that.
I started using narrow mtb rims in the late '80s. Much of the time I was using 1.5-1.9" tires. Found I would have fewer pinch flats at the same pressure with these tires on a 20-22mm rim vs the more common 28-32mm rims of the time. Dropped a huge amount of weight, too. A rolled down MA-2 is only ~425g vs the 600g of many of the wider rims.
BTW I do want a set of your new rims.
