What if a fork is cut too short?
21636 Views 58 Replies 19 Participants Last post by  kstovesand
Just curious, is there a way you can "save" the fork and install a new tube at full length and re-cut again? I know it's not good to cut too short but I was just curious if there's a way to save a fork if this were to happen.
1 - 20 of 59 Posts
usually you will need to get a new upper assembly of the steerer tube, crown and stanchions but some fork companies will press a new steerer tube in the crown for you
highdelll said:
If this is real, wouldn't it be easier and less time consuming to just grab another board and cut it correctly?:confused:
~~>wooosh!~~>
:your head:
:lol:
That's what I thought, fake vid. I tried to watch most of it but the old man was boring.
yeah, it is kinda boring ;)
How short is to short ?? Smaller Headset, smaller Stem height wise and you can get a extender which bolts on like a stem but goes up to attach another stem higher.
highdelll said:
~~>wooosh!~~>
:your head:
:lol:
lol
catch it off the back wall...
Is the measurement with headsets listed on pricepoint in regard to the height, or how far out they go? Such as 25.4mm vs 31.8mm, etc.
That's a great video....how in the heck did you find that?
You'd be looking for a headset with a low "stack height".
Thread with good info here- http://weightweenies.starbike.com/forum/viewtopic.php?t=20376
If that's the case, what does the 25.4 or 31.8mm measurements mean?
Bar clamp diameter
Not that anyone is serious about the question...
I cut a Fox RLC 29 too short about a year ago. I made it work but called Fox and they will put in a new upper assembly for about $300 (as I recall). Good suggestion up top on low profile headsets.
Holy ****. No thanks... I was hoping you could spend a couple bucks and just get a new tube pressed in place...
see post #14
Zoke2 said:
see post #14
Yeah. I see that. But still... I thought it'd be a little easier (aka cheaper) to get a new one pressed in...
highdelll said:
I cant even count the number of times I have had people go look for bored stretchers. I had a guy that worked with me take an old car rim into NAPA and ask the guy working there how much a "rim job" would be..... ignorant people make me laugh so hard.
1 - 20 of 59 Posts
