1 - 5 of 5 Posts
I have a 8.1 frame and i need a new headset. I believe they use zerostack dont they? there are about 3 types of headset and i want to make sure I order the right type. thanks
You should be able to use any Zero Stack type headsets from W T B, C ane Creek, Ritchey... The Zero Stack type has cups in either steel or aluminum that press into the frame.
Chingy said:
cool, thanks. i thought so i have ordered a cane creak zs-2 from jenson. are they any good?
Yep, that headset should work out nicely. Sealed cartridge bearings means you only need to buy replacement bearings if needed and not an entire headset. Should be lighter than the stock one on your bike.
1 - 5 of 5 Posts
