I started mountain biking in the late 80s, when steel frames, rigid forks, and toe clips were the norm. I was an early adopter of Rapidfire shifting, suspension forks, 21 speeds, and clipless pedals (may my Onza elastomer pedals rest in peace!).
The main reason AGAINST these new technologies was simply weight. Few mountain bikers at that time were willing to add the small additional weight to their bikes that these early technologies represented.
Back then, mountain biking primarily consisted of XC style riding and racing so while roadies and tri-geeks obsessed over aerodynamics, mountain bikers obsessed over weight. Sub-25 lbs. mountain bikes were common.
As technology improved, most was not widely adopted until other technologies (aluminum, carbon fiber, CNC machining, etc.) could allow the total bike weight to stay under that 25 lbs. threshold. Change a fork from rigid to a RockShox Mag21 and gain a pound and a half. But replace your bolts with titanium and switch to an aluminum frame and you're back under 25 lbs.
I quit riding for a decade and then came back to find things have changed dramatically. The trails I'm riding today haven't changed much, if at all. But the bikes have changed and it seems bike weight is irrelevant. I see guys riding the same trails I rode in the 80s on bikes that are a full 10 lbs. heavier.
How did bike weight go from being the most important bike spec to nearly ignored? Even my beloved Yeti is making heavier and heavier bikes. My ASR-5 is right at 25 lbs. but Yeti discontinued that bike for newer and heavier models. 7 pound frames? 30 lbs. trail bikes?
Is the lift-served market bleeding into the "climb what you descend" market? Are riders just so strong now that riding a 35 lbs. all-mountain bike on a XC trail is effortless? Are trails so rough that 7" of suspension is needed for every root and rock?
The massive wheel-size debate is the best example of this. Proponents have spent thousands convincing people of the advantage of slightly better rolling while ignoring the fact that they added significant weight to the absolute worst place on a vehicle to add weight.
When did weight stop mattering?
