1 - 20 of 24 Posts
Just tore down my newest ( oldest) bike and need to soak and clean the bearing and other hub parts. It looks like the grease could be the original 70 year old stuff, super baked on and hard. Looking for suggestions what to use to break that crud down.
Brake clean for anything non-painted/anodized/polished. EG: loose ball bearings and races.
For finished components or anything with plastic or rubber, I use electrical contact cleaner.
> /dev/null 2&>1
I left a chain in engine degreaser from my local auto store, and, it rusted. I forgot about it for, I believe, 4d. I then realized most degreasers, including all varieties sold at my local Napa and Oreilly auto, are water based!
RAKC
I use pb blaster to break the grease down then brake clean to clean up. No need to soak anything, just spray and wipe. Just don't spray pb on rubber or plastic. I always make it a point to remove what I need to clean from the bike and any bits (rubber seals etc) so nothing gets damaged.
Sent from my Nokia Stupidphone using Tapatalk
Trail Tire TV on blogger
Citrus solvent, straight up. Non-water based, smells nice, won't kill you as fast, works better than the hardcore stuff IME.
yup, any decent citrus degreaser is going to be the best working for your dollar. Simple green is decent too. I get gallons of orange degreaser from home improvement store for right around 10 buck.. mix it with a bit of 90% rubbing alcohol for quicker evaporation and it leaves less behind also.
P.S. they are water based though
1 - 20 of 24 Posts
