I only put water in it. I empty and hang to dry with the camelbak hanger after each ride. If I forget to empty it, which has happened a couple of time. I put one tablespoon of bleach in there and fill with water, let sit overnight. Rinse in AM. Good to go.i_suck said:^^^?
i use the tablets but they are kinda pricy
Amen! That's my exact regime to a "t".Geist262 said:I use hot water with about a cap full of bleach. I let it soak for a bit, then rinse. I then fill it back up with water and baking soda and soak. Then its ready to go. Stick the bladder in the freezer when your done riding to prevent stuff growing.
If your camelbak gets left in the car for awhile and gets kinda chunky, empty a can of coke (has to be from the can) into it and let it sit for about an hour. When the chunks are dislodged, empty it out and put a can of sprite in it. Let this sit for about an hour (also, don't forget to let the coke and sprite into the tube and bite-valve).Just J said:I have been riding local short rides (plenty of them but not far enough for a Camelbak) so unfortunately I forgot about my bladder after the last long ride (about 2 months ago!) and it had all sorts growing in it.
I washed it out, used the Camelbak cleaning brushes to get in the tube and into the hard to reach places. I out bleach in it, left it, and went back to it the next day to repeat the whole thing again.
I think I got it clean enough, there's a bit of staining, but everything seems to tast ok!
I'm definitely taking your advice and putting the bladder in the freezer from now on!
yep, same here. never cleaned it. the newer bladders have antimicrobial coating which eliminates bad stuff from growinggtdrew said:Only use water. Have not cleaned it in over a year and it still tastes and looks fine.
I've used Listerine. It kills stuff. Plus it leaves a minty taste, which is better than rubber.:thumbsup:BBOC said:I have done bleach and denture tabs. I wasn't really impressed with either as they leave a residual Taste. I good idea I heard that I will try next time is to use Listerine.
