I sent my rear shock (Stratos Helix Pro) in to get serviced and came up with this idea as a possible way to ride my bike until the shock returns. I have cut a Ritchey seat post down, drilled holes 6.5 inches apart and slapped in onto my bike. I've ridden it around my yard and it seems fine but i have my concerns.
1. Will it hurt the rear linkage at all?
2. Will the seat post shear the bolts holding in onto the frame and rear linkage? The shock has a shaft that the bolt goes through. This is just two drilled out holes.
3. Will the seat post hold up if everything else is ok?
4. How hard would you ride if you would ride it at all?
Thanks for your help.
