New Reign X1 here. It came with a 500lb coil and with the preload cranked all the way down it still sags a little bit more than I want. Would a 550lb be enough or should I jump to a 600?
How many turns of preload? If it's like 8 turns, then probably worth going up 100lb.Moustache rider said:New Reign X1 here. It came with a 500lb coil and with the preload cranked all the way down it still sags a little bit more than I want. Would a 550lb be enough or should I jump to a 600?
If you are using 8 turns, back that off right away. Most shocks and springs are designed around 2 turns max. Knowing that most engineers aren't going to design with zero safety factor or tolerance allowance, I bet 4 turns wouldn't cause damage. That said, if your spring goes solid, your shock will go boom!!!fsrxc said:How many turns of preload? If it's like 8 turns, then probably worth going up 100lb.
The thing is, Maestro suspension is designed to work with a decent amount of sag (I don't know the exact number, but I've heard 30-40%) so if you "like" a firmer feel, and run less sag, the bike won't work the way it's designed and you would be better off getting a bike with less travel, like a Trance or something.Moustache rider said:Thanks for the responses guys. Looks like a 600 spring may work best for me. I'm still playing around with the adjustments and getting my set up dialed in. I tend to prefer less sag on my FS bikes than most people. Possibly because I ride a hardtail half the time and am accustomed to a more firm rear end.
avid28- alas I live in Colorado.
Nope. That is only true with DW linkage. People just assumed they were the same.fsrxc said:The thing is, Maestro suspension is designed to work with a decent amount of sag (I don't know the exact number, but I've heard 30-40%) so if you "like" a firmer feel, and run less sag, the bike won't work the way it's designed and you would be better off getting a bike with less travel, like a Trance or something.
Another option, you could run proper sag, but add some boost pressure to firm up the compression damping a bit, which might feel better to you.
