i broke my chain the other day. i was wondering what chain is a good strong chain for big guys.
recomendations are appreciated.
thanks in advance.
drew.
thanks in advance.
drew.
XTR chain with SRAM Powerlink is the shiznit. Never broke this setup, and XTR chains take me for frickin' evar to wear out. I wear SRAM chains past the wear limit in 3-400 miles, but I get at least double that out of XTR chains.perttime said:I think all Shimano instructions say you should always use new pins.
I have had two Shimano chains break on me and both times it was a badly made joint. Still running Shimano chains and they are working fine. Recently started using them with SRAM Power Links.
(HG-53 is sort of OK chain, CN-7701 is the best I've tried. I am not all that big by clyde standards.)
+1 for the 991TLL said:SRAM 971 or 991 work well. I have yet to bust one.
Broke a 971 on it's second ride. Not the power link, just a normal link came apartTLL said:SRAM 971 or 991 work well. I have yet to bust one.
i totally agree with everythng but the last paragraph. quick links always seem to explode or separate on me. After about the 5th link, they have become an emergency-only tool. YMMV.vmajor said:SRAM 991 got totally destroyed by me. The fourth time it broke, it actually broke in two places, at the same time. Yes, I ended up with TWO chain fragments.
I am now using the Shimano LX (HG-73, made by KMC) as my featherweight friend breaks his Shimano XT almost every time we ride. Its rather hilly here. The KMC is going strong. My next chain will be a KMC X9 in TiN gold finish
Also, if you do buy Shimano, forget about that pin that comes in the package. Its worse than useless. Use KMC or SRAM missing/magic links instead.
V.
