Sorry if I am posting this in the wrong area. I am a newbie when it comes to angle sets.
I have a diamondback catch 2 2017. tl;dr please help me understand how to select the correct angleset for my bike! I think a 2 degree change angleset is what I want but I have no idea which model i need.
My thought process and project:
The DB Catch has a head angle of 68 and a fox float 34 130mm with 51mm offset. I am looking to upgrade to a fox 36 150mm with 44mm offset. I was assuming this would slacken the HTA by one degree but also slacken the STA which is not good. So I was wanting to use a 2 degree angleset to further slacken the HTA and slightly fix the STA.
Looks like my BB raises a bit with this fork change. I have seen online that they suggest to run the 130MM fork at 15% sag. I assume that the geometry quoted by DB is using this sag figure. If I run the 150MM fork at 20% sag, that shortens the forks length by 10.5mm which should help the BB go down the rest of the way and fix the STA the rest of the way.
1. I hope what I am saying above makes sense and is correct. Please tell me if I am way off base. Will this affect any other geometry of the bike?
2. I don't understand at all how to select the correct angle set to be able to do this and was hoping someone could explain this to me. Thanks so much!
