Dear MTBR
I posted a little earlier about adding a disc brake to my old-ish giant cadex, and, if it all goes wrong, thats what happens... however
I really quite fancy the idea of getting it sorted!!
So what i'd like to know, are there any thoughts on adding an additional piece of carbon tubing between the rear triangle, without a picture, i'd describe it as, where you would normally have a disc brake caliper, between the seat and chain stay's a small tube of approx the same diameter as the stays.
What adhesive would I need to use for such a task? normal epoxy with carbon stands? I'm pretty comfortable with the mitering, the laying and wrapping?
Also
As the bike is now a singlespeed, i'd quite like to change the rear dropouts to sliders so I can get a perfect chain tension without a doofer doing it.
What steel should I look at using for doing this, or, could I buy appropriate dropouts and modify them to fit my frame?
cheers and thanks in advance
Jonathan
Also
Jonathan
