1 - 14 of 14 Posts
I recently stripped out the derauiller hanger threads on my Bullit and as such I've been looking around for possible alternatives. As of now, helicoiling is about $60 and a new swing arm is around $260. I was planning on helicoiling it, but then I saw that Supergo is selling the Weyless 67 frame for $229 w/o shock. So I'm thinking why not just switch all my componentry over to a brand new frame with replaceable drop outs (not to mention I can run a through axle if I want to)? My main questions are:
1. How do the two frames compare (stiffness, geometry, quality, etc.)?
2. Are the shock lengths the same (meaning can I just swap my 5th from my Bullit to the 67)?
3. Is this a good idea?
I dunno about the shock lengths on the bullit , A 9in shock with whatever at least a 2.75 stroke is what you need
Weyless is better. Better tubing, replacible dropouts...ETC except the are outta business for a bit.
It is a good idea.
Just wait till school gets out and raptor dude gives you a lecture on this bike...
Now with flavor!!
Or you could buy a $3 t-bolt.
Or get your own helicoil kit for about $20 at most.
Whoever charges you $60 to put in a helicoil should be castrated.
N* Bomber Crew
I roll a 67 and its a great frame. I would definetley get a new frame. 5 year warranty, good tubing, lots of good details, replacable DROPOUTS, etc. Get it...its a really fun ride.
Just get one of these and save your cash for something else...
Dropout Saver, Dropout Thickness < 7mm /Each
Price: $9.50
Item #WB-DS2: Stripped rear derailleur hanger threads are not uncommon on mountain bikes, and repairs can be difficult. An easy solution is to drill out the old threads with a 15/32" drill and slide in one of these precision stainless steel inserts. They provide new 10 x 25.4 (1mm) threads so you can remount the derailleur quickly and securely. Many frame manufacturers are using these Re-Threadz inserts for repair of bikes under warranty.
https://www.thethirdhand.com/index....uts/Braze Ons&tc=Thread Repair&item_id=WB-DS2
That bike looks like a great deal! I think i may get one. Does any one know how much it would be to get the frame a budget coil shock and a seat post for that thing? Im tryin to be under $500 that all the money i got. Any recomendations on wear to get the rear shock and the seat post would be great too. thanks.
you should be able to keep it around 500, 200 frame, 300 shock 20 seat post, I got the shock for mine off ebay, thats what I say to do. the 67s arnt bad bikes got mine last spring and no regrets for a $200 frame I love it
Price: $9.50
There's your ticket right there. Anything else would be silly.
Discussion Starter · #14 ·
I definetly will not be just throwing away my Bullit frame. However, I was thinking that if all the parts are transferable between the Bullit and the 67, then why not pick up the 67 for $219 and that way if my swingarm does fail in the future, I'll have a back up anyway. Also, I may have to get a new rear wheel, so I was thinkng of upgrading to a through axel.
1 - 14 of 14 Posts
