Which pedal are considered the best wellgo or shimano?
If you are looking for SPD pedals, then fine. Might I recommend that you try time or crank bros. I am a Time convert from shimano. Best move I ever made. Better engagement in the mud, no adjustment required, perfect float. All around I felt it was better than SPD.malariavalley said:Which pedal are considered the best wellgo or shimano?
The wellgos and shimanos load up in muck, loamy dirt or dirt with alot of material on its surface. This will cause premature and/or lack of release of the shoe from the pedal.malariavalley said:Which pedal are considered the best wellgo or shimano?
this is true if you are talking about the older , 858, 747, 515's, etc but Shimano's mud performance improved dramatically with the 959 design and now 520/540 models. Their mud performance is easily as good as anything else.jrm said:The wellgos and shimanos load up in muck, loamy dirt or dirt with alot of material on its surface. This will cause premature and/or lack of release of the shoe from the pedal.
