nice job, very cool to be able to put your own wheels together :thumbsup:
My race weight is about 165lb. I'm not exactly a clydesdale.jncarpenter said:If you're a big boy, you may not be too excited about flexy wheels. Personally, I would have gone with the arches (at the very least)...if not flows.
Report back on your thoughts...
OK...they should be a decent set of race wheels for you then. If you do decide to build up another set, consider the flows instead of the arches. Not much more weight, but less similarity in wheel builds.BobShort said:My race weight is about 165lb. I'm not exactly a clydesdale.
I'm definitely wondering how the bike will be for stiffness. Later I might build up a medium weight set of wheels with Archs and some sturdier hubs than AC. Use them for every day trail riding and keep these wheels for racing.
Agreed, I hope the rider weighs under 180 #s at 6' 3" with 355's, otherwise things ain't gonna last too long, unless those are race day wheels only.jncarpenter said:If you're a big boy, you may not be too excited about flexy wheels. Personally, I would have gone with the arches (at the very least)...if not flows.
The spokes are Wheelsmith DB14 with brass nipples.RandyBoy said:Agreed, I hope the rider weighs under 180 #s at 6' 3" with 355's, otherwise things ain't gonna last too long, unless those are race day wheels only.
Edit: D'oh!, he beat me to it. Good luck with the race day wheelset. What did you use for spokes, nipples, and what did you tension them up to in kg's?
Ah yes. Weight. Now you asked for itRandyBoy said:Looks rather similar in build to my XL AIR. What's she weigh 25 to 25.5 pounds?
Hmmm, you must stand and mash, I see no seat in the build?BobShort said:Ah yes. Weight. Now you asked for itMy buddy is a weight weenie so I borrowed his gram scale just for kicks. Might as well while everything is in bits.
The build ended up at 24.5 lbs.
The only things I'll probably upgrade eventually is the bar (Salsa Pro Moto Carbon) and maybe the disk brakes (Formula R1s). That would put it under 24 lb. The Shimano pedals are also boat anchors but I just like how they work to much to go to something lighter.
Weights:
Niner Air 9 XL 1670
Fox F29 RL 80MM 1753
FSA Headset 116
Niner Seat Collar 26
Thomson Elite Seatpost 243
Easton EA70 Stem 150
Easton EA50 Flat Wide Bar 264
ODI Ruffian Grips 108
SLR XC Grips 184
Shimano 540 Pedals 346
Front Wheel AC / DB14 / Stan's 355 771
Rear Wheel AC / DB14 / Stan's 355 879
Front Skewer AC 49
Rear Skewer AC 52
Front Tire Hutchinson Python 29er 646
Rear Tire Hutchinson Python 29er 658
Stans Sealant 120
Front Brake XT 301
Rear Breke XT 306
Front Rotor XT 6 bolt 118
Rear Rotor XT 6 bolt 124
Rotor Bolts (both) 26
Caliper Adapter 39
Cranks XT 773
Bottom Bracket XT 97
Cassette XT 262
Chain XTR 267
Front Derailleur XT 146
Rear Derailleur XT 222
Front Shifter XT 123
Rear Shifter XT 125
Shifter Cables 48
Bottle Cage 60
Headset Spacers 12
Total: 11084 grams = 24.4 LBS
SLR XCRandyBoy said:Hmmm, you must stand and mash, I see no seat in the build?
Saddle is an Selle Italia SLR XC. It's off my old bike. I've found it to be quite comfortable and very light.triguy6 said:Nice build! Impressive that you built your own wheels. What did you use for a saddle? Also, if you wanted lighter pedals, Eggbeaters are the way to go. The brass cleats wear out quicker than I'd like, but they're easily replaceable. I just love the ease of cleaning the pedals compared to SPD's.
