Parts look good! What frame are they going on? Can you make the next batch of pictures a little smaller? These are hard to view on a laptop.
Hi Russya, I already have an SMP Glider. Pretty much the same, but a few MM wider and longer than the full carbon. Been riding it for over a year now, and love it. Longest ride I've done w/ the SMP Glider is 6 hours. IF you do get an SMP, be patient, took my butt approx. six rides to get used to the different pressure points on my butt, but now, it feels super comfortable. I'll let you know how the Full Carbon feels, but, I have a feeling I am going to love it!russya said:Props for being able to part with the cash for a full carbon SMP. I've been wanting to get one, but can't bring myself to part with that much cash for a saddle I may not like. Have you tried it yet? I'm hoping it's flexible and not stiff
From the Tricon manual - tubeless set up should be with UST tire.Jfair27 said:why not run a DIY tubeless setup with the same tires non UST version? wouldnt that be like a 400-500 gram savings in tires?
I was suprised to read this because they are making the wheelset in a road version and I have never seen a UST road tire.The Tricon XM wheels were designed for use with UST* (Universal
System Tubeless) tubeless tires. It is also allowed to use the Tricon XM
wheels with regular tires, inner tubes and rim tapes according to the
ETRTO-Standard. A rim tape should be mounted, if using an inner tube.
Actually, I am going to start w/ the Stronglight CT2 110 BCD 40t chainring. Weighs in at 46g, so total weight for my Rotor 3D cranks are now:limba said:Sorry Kevin, I must have scrolled over the chain ring pictures.I didn't see them. I could have done the math in my head. You're getting an XTR bb right?
Also, why did you choose the Rotor setup with conventional rings over Sram XX?
Not sure if the 2011 is lighter.I think their website is a bit misleading, they show a pic of the 15mm TA, but that weight is for the 9mm QR I believe. My EXC 150 15mm TA weighsTheRedMantra said:Dt lists the exc 150 as 1575g, what a difference! Is the 2011 lighter or is it the same?
