1 - 5 of 5 Posts
Looking to build up a light wheelset that I will be careful with how I use (not just racing only per se, but I won't abuse it). I will use it for some endurance races.
I'm 165 lbs or so and race in the midwest (not terribly technical)
want to use dt spokes/nipples... how light can I get away with?
likely 2.0/1.5 revolution spokes? or can I go lighter?
excited to get this stuff ordered and built up-
Stans ZTR Race 29er Wheel sets uses DT Revolution 2.0/1.5.
When I built a 26er Wheel set years ago with the Stans ZTR Olympic rims I used DT super comp (1.8/1.7/2.0) for durability. I have not had any problems, so I am thinking of going DT Areolite next. The blade helps your true the wheel, which is the weakness of the DT Revolution 2.0/1.5 because the twist so easy.
Former Bike Wrench
What exactly did you have in mind that is lighter:eekster:
Neither Sapim CX-Ray or DT Aerolite spokes are any lighter, maybe Marwi Ti-Dye which make for a rather flexy wheel.
I just pulled the trigger on a build, single speed, for my Misfit. The builder, Ligero, for my weight of 157 lb. go DT Revolutions all the way around. Troy built me a set of 1270 gram clinchers for my road bike that are 4 years old this month and still spinning sweet.
Here is what I went with:
Industry 9 red single speed disc hubs
black DT revolution spokes
Red DT alloy nipples
Stan's Crest rims
1 - 5 of 5 Posts
