I am trying to wrap my head around how various factors influence weight on the front tire and how that impacts front end cornering grip and steep climbing stability.
My first question has to do with stem length because as a tall rider my handlebars are much further away (vertically) from the tire's contact patch than for a shorter rider but this also means my weight is further aft for a given stem length. Let's compare the same bike in two different sizes, both with a 67.5deg HTA.
Bike 1 Baseline smaller bike - 10cm headtube, 60mm / 6deg stem, no spacers under stem
Bike 2 Taller rider bigger bike - 13cm headtube, 60mm / 6 deg stem, 30mm of spacers under stem
Bike 2 has 23mm less effective total reach than Bike 1 meaning, I think, that there is a lot less weight on the front tire of Bike 2 for cornering grip and steep climbing stability. Put another way, Bike 2 would need an 86mm / 6 deg stem to equal the same final forward weight point of Bike 1. Surely this is significant when talking about handling, traction and body position on the bike, especially on the new Long, Lower, Slacker trail bikes that require the rider to be more 'over the front' to get the most of out the new-style geometry? My thinking is that for taller riders / bikes it would be beneficial to keep the frame Reach number more conservative and add cockpit space with a longer (20-30mm) stem vs a standard small/medium bike set-up for a shorter rider with an optimal 50mm stem, to keep the front weight more or less the same for the bigger bike.
My second front end weight question is - what happens when the chainstay length changes? Lets assume a large bike with 500mm of reach, 829mm front center and 432mm chainstays. What happens to the weight distribution when the chainstays grow to 442mm (+10mm) but everything else stays the same up front? Does the front tire gain or lose weight, aka traction?
