anyone know the weight of the trek 69er frames, geared and SS, so i can compare it to my carver frame, cheers.
Unfortunately the Trek 69er 3x9 has already an almost-too-high BB with the stock 26" rear wheel.Cracked Headtube said:RsR- I can't help with your Trek (?), but on a side question. How does the 650B fit into a standard 96er aluminum frame?
My large 19.5 was 25lbs pretty much flat on. Stock frame is right around 6lbs if I remember correctly after rebuilding it this winter.RockStarRacing said:23lbs as stock? everyone has always said its 25lbs stock..............
Heh its a heavy bike! For a SS hardtail anyways. 5.5 - 6 is right about where I had the large 19.5 but it was on the ole bathroom scale so it's not terribly accurate. Wouldnt surprise me if it was closer to 5-5.5.RockStarRacing said:6lbs! that is TOOO Heavy! a medium carver 96er is about 4.5 lbs.
