1 - 4 of 4 Posts
The Kenda website says 888g for this tire, which seems way too heavy for this X country tire. Does anyone have first hand experience with its actual weight? (Note: Nevegal specs for the UST version are posted on the Kenda website at 769g)
Also, I plan to run tubeless with this tire on a mavic Crossmax UST wheelset. Could anyone tell me if I need to fill with Stan's solution, or does the Small Block 8 work fine without the solution.
Many Thanks!
Premium Member
Many Thanks!
Mine weighed 760-790g.
No sealant needed.
Hello
Many Thanks!
If you run sealant on a Kenda UST tire, it will void the warranty. I use sealant on my Kenda small block 8's and haven't flatted in nearly two years. UST tires normally run heavier than comparable non-ust tires. It's a good tire, side walls don't get easily sliced compared to a lower weight ust tires that come in pretty boxes.
1 - 4 of 4 Posts
