1 - 12 of 12 Posts
I struggle finding the right fork for my new Spider.
The options so fare has been:
1) WB Fluid 135mm - 20mm TA
2) WB Magic 100mm - 20mm TA
3) Reba Race 100mm
4) WB Fluid 130mm - 20mm TA
Yesterday I joined a party of bikers on some rough trails in the forest around Oslo - Norway. My Gary Fisher HT with a 80mm Manitou fork didn’t cope very well with the descents.
I guess I would like as much travel on the fork as the Spider can handle, and a fork as strong as possible to handle my 205 pounds without gear. I like the idea of a 20mm TA.
Any views on this?
PS – I have asked WB about some documentation for the F135, but only got
“The Fluid 135 uses a coil spring with air assist, and an open bath damper”. Anyone who has anything more info about it? How about weight?
Reviewer/Tester
PM Mikesee. He posts on this board regularly. He can fill you in on the WB 135 TA as he is currently testing one.
R.
The Beaver
I just got a GF Rig and it cam with the RS Reba SL... coming from 6+" forks, mostly marzocci, this fork is amazing once it's dailed in (and that only took 15min). It's set at 80mm now but I am thinking about bumping it up to 100mm soon.
If you do go with a 20mm axle you are going to have to deal with a new hub, which either means new wheels or building up a new front wheel at least. I don't see the reason for a 20mm on anything less than 150mm of travel, unless you are hitting the Dj's
My 0.02
Flight Junkie
I just got an WB F 135. Axle/Crown is 535. Weight is 4 lbs 6 1/2 oz's with the thru axle uncut. Reba is 3.97 lbs cut without skewer. Less than 1/2 lb and you get a coil thru axle with 5 1/2 inches travel (no lockout though). My bike won't be built for another 2 weeks, so no report on fork yet (although it seems buttery smooth out of box which is unusual for WB forks)
Discussion Starter · #6 · (Edited)
Are you waiting for an Intense frame fram as well?
What kind of hubs are you planning to use?
Powered by ice cream.
I have lots of time on a Reba, about 20 hours on the F 135, about 40 hours on the Fluid 130, and a ride around the block on the Imv 100.
Toss the Fluid 130 off the list. I think it sucks unless you want the lightest long travel fork you can get.
I like the Reba a lot, and it is a very capable, reliable fork for what it is. I still think it or the IMV 100 is the best match for the Spider's cross country chassis.
The IMV 100 with TA is simply, hands down, the stiffest chassis in a fork I have tried. Stiffer than both the F 130 and F135, which makes sense since it is similarly built, but with shorter legs. Not enough time to judge damping. This will probably end up as my preferred SS fork.
I like the ride of the F 135 the best. I did recently blow an oil seal on the fork, which by all accounts is the first problem WB has had with this fork in the 6 months they have been making them. They have taken good care of me on this issue thus far.
Again: What is your goal with this bike?
Racing?
All day epics?
Both?
Techy stuff?
What you want to do with it, will determine what fork. Honestly, the F 135 is more fork than I want for most of my rides.
1 - 12 of 12 Posts
