I'm looking for comparisons of the behavior of front tires when they start to loose traction in loose over hard, very dry conditions, with flat or shallow down slope corners and off camber shallow descents. Even if I have to trade off less grip at good lean angles, I will happily do it if the tire slides a little bit before a total washout, so I can react to it. I have had too many sudden washouts with my DHF 3C MaxTerra 27.5 x 2.6 (i30 rims) in these trail conditions, so I'm considering switching it for an XR4, or maybe a Hans Dampf Addix Soft (27.5 x 2.6 again), after reading reviews that indicate that these more rounded tires with intermediate knobs are more forgiving in this way.
While I have mainly been focusing on technique, weight distribution, tire pressure (20 psi front, 207 lbs rider + gear, not including bike, but I am going down to 18 psi next), shock setup, and have purchased a zero rise bar and negative rise stem, I want to do everything I can to avoid a sudden washout, and trip to the hospital with another broken finger.
