They've always been basic. A squishy bit of plastic does not make a good damper!
Sent from my IN2023 using Tapatalk
They've always been basic. A squishy bit of plastic does not make a good damper!I'm not that sensitive of a rider, but even I can tell my Motion Control dampers weren't/aren't that good. They especially pack in too easily on rapid hits.
So was wonderin'.... Was Motion Control "very good" when it first came out and now we're just spoiled? Or was Motion Control always well behind the popular state-of-the-art?
Naw, it was crap when it came out, spongy crap. Mission Control on the other hand, that was an actual proper compression valve and worked pretty decent.I'm not that sensitive of a rider, but even I can tell my Motion Control dampers weren't/aren't that good. They especially pack in too easily on rapid hits.
On my MC forks (Duke SL and Reba Team) there are two adjustments, one for the width of the orifice, and another for how much compression of the coil is needed to initiate blowoff. So you can close up the orifice and ride it as a hard lockout that just blows off for big hits, or you can open the orifice a bit and set it up to blow off on moderate hits and get more of a digressive compression damping behavior.Is it still the same thing now that it was at the beginning? My impression is that the tube was supposed to contribute to damping but it's been stiffened up and simplified into a blowoff for the lockout. So the adjustment just changes the width of the orifice from wfo to lockout. Which puts it exactly one adjustment up from TK, which is one hole, right?
I also see shim versions that seem to be dead and gone in the Charger era.
Yup the valve worked exactly the same back then, the spring tube was always intended to be the blow off mechanism where as pressure built up in the base valve the tube would compress until it contacted a plunger that opened the check valve. Boxxer team and World Cup also had a shimmed piston inside for high speed damping, but otherwise yes, the fork steve peat won the World Cup title on was probably less sophisticated than a modern yariIs it still the same thing now that it was at the beginning? My impression is that the tube was supposed to contribute to damping but it's been stiffened up and simplified into a blowoff for the lockout. So the adjustment just changes the width of the orifice from wfo to lockout. Which puts it exactly one adjustment up from TK, which is one hole, right?
Lyrik select is a lot better than moco in every way. Charger 2.1 is quite a lot better again thoughHow does MOCO compare to the IFP system in the Lyrik select?
I came from MOCO to that lyrik but now tossing up buying a charger 2.1 to fit in it.
