Yes pumping a tubeless bike tire above 60psi is not a good idea and you may have (permanently) damaged the bead by forcing it over the rim. Be very careful of that tire or just replace it if you like to be on the safe side. (The cost of a tire is dwarfed by the cost and involved in medical emergencies should you become injured if that tire looses a bead while you are riding)mzungo said:
Any bike tire (any tire FTM) can explosively deflate if it is over pressurized (either by blowing out a sidewall or by popping the bead. You can also loose a bead on a tube tire if the bead is not set evenly around the rim.
