I recently installed a new STYLO crank on my SS but wanted to swap out the 32T original ring for a SURLY 33T.
As the Surly is 2.25mm thick compared to the Truvativ 3.25mm the nut or female potion of the chain ring bolts were too long, threading completely into the nut without actually clamping the ring. ( this outcome is quite obvious to see)
I bought a set of PROBLEM SOLVER alloy chain ring bolts, as they had a slightly shorter nut.
I checked as I assembled the crank and ring to be sure the nut was long enough to protrude beyond the crank "spider" without being long enough to duplicate the problem I was trying to fix.
I would estimate the nut protruded about HALF way through the the rings thickness.
After about 5 or 6 hours of hilly single-track I was checking chain tenion when I noted that the "arm" of the crank spider and the "arm" of the ring were no longer aligned.
Removing the bolts I found that roughly a third of the nuts circumference that was protruding into the ring had been sheared off and the ring was now resting on the threads of the bolts..
I filed the original steel bolts to fit EXACTLY and it has been fine.
I'm not faulting PROBLEM SOLVERS or alloy hardware.
I am just saying that simply using SINGLE SPEED CHAIN RING BOLTS may or may not get the job done and I should have paid closer attention to being sure I had a PERFECT fit.
I shudder to imagine being 3/4 of the way up a monster climb and having the chain ring and crank go their separate ways.
