1 - 3 of 3 Posts
· Registered
I've got an old old old (almost as old as me) Trek 820 single trac w/ orig. fork and wheels. I want to up grade to disc brakes is this possible or will i have to go get way to many new parts to make it worth it. I been considering going to a full suspension bike in the future but I also have a family of Ethopians to feed first.
· I post too much.
Does your fork and frame have disc tabs? If not there is no way you can use disc brakes
Frame disc tabs:
Fork disc tabs:
You will also need disc compatible hubs that will have holes the rotor can bolt on-to:
If you've got disc tabs on frame and fork already, upgrading your wheelset will fix your hub problem, you can then upgrade to disc brakes. I recommend you use avid BB7 mechanical brakes, they are easy to work on and are easily the best mechanical brake out there, and by a lot.
Hope this helped
1 - 3 of 3 Posts
