1 - 11 of 11 Posts
· Human Test Subject
So after 3k miles of indoor riding I came to the realization that maybe I shouldn't have my gravel bike set to the 700c road setting. Does anyone have theirs set to 650b mountain?
The different settings should level it out more, but since I also have a Kickr Climb and a 122 year old house I can't level anything. I do know that my normally comfy Cambium suddenly feels weird.
· Registered
Or ride outdoors?
Discussion Starter · #4 ·
Or ride outdoors?
I live in MN and it was -20F this morning. My record is -28F, but that kind of riding is much different than indoor training.
Couldn't you level it with pieces of wood?
It's on a rocker plate, so no. Also I wouldn't shim it if the wheel diameter could be met more closely with a setting on the Kickr vs chunks of wood under the 4 spots feet on which it rests.
· Registered
Currently set at mtb 650b, which essentially raises the rear of the bike.
Ahh... I get it now... when set for 700c the front axle was lower than the rear. I find that I am far more successful on the trainer, especially for longer ride (>2 hrs) with it the other way round, the front axle elevated. But it sounds like you couldn't do that.... this is an interesting adjustment I've not seen before.
· Registered
I also have the Climb and some times it appears to have a mind of its own as to where 0% should be. I keep a tape measure handy now and measure the front and rear thru axles to make sure it is level (mainly when using ERG mode).
Discussion Starter · #10 ·
The 650b setting was a bit better. I only noticed it after starting a workout plan that requires more sitting than I typically do. Also on some dumb pedaling drill workout it said 'hold one leg off to the side and only pedal with the other' and I realized I could touch the ground while still pedaling.
Still need to measure axle heights and readjust my saddle angle.
· CEO Product Failure
I'm running my bike on the 700cc setting on my Kickr and using a CycleOps (front) wheel block with 3 heights. A wheel block may be another option for your set up. The different heights are helpful on different courses (flats vs climbs vs rolling hills vs tempo rides, etc.).
1 - 11 of 11 Posts
