1 - 5 of 5 Posts
Discussion Starter · #2 ·
granny.gear said:
Fox RP3 is a great rear shock for the VT.
Fox R is ok, but best if it had adjustable pedal platform like RP3 for VT.
5th Element is also good, but may not be as durable.
I assume you want an air shock?
Just buy one with same length 190mm (bolt to bolt) with 50mm shock stroke.
What about hardware ?
I've read that rp3 is harsh on small bumps, did you try it on VT ? How does it compare to swinger ?
1 - 5 of 5 Posts
