I'd like to offer my experience to hopefully add some value to this thread and to the OP....
I've ridden all 3 designs.
VPP bikes I've ridden:
Tracer VP (tested and currently own)
Carbine (short test ride)
Carbine 650b (45min on twisty rocky ST)
Intense 6.6 (long time ago)
DW Bikes I've ridden:
Ibis Ripley (short section of smooth Moab ST)
Pivot Mach 5 (a few rises)
Turner 5Spot (1 short test ride)
Split Pivot bikes I've ridden:
Devinci Troy (brief test ride)
I currently own a 2010 Tracer VP and here are some general, personal observations and comparisons:
1. DW vs VPP - DW climbs steep and/or tech chunk better and generally pedals better, but I think (tracer vs Pivot M5) that Tracer is a better DH machine - stiffer fork, slacker angles. Generally comparable.
2. Carbine 26 vs 5Spot (same test session) - Carbine felt much more lively, but (and this is HUGE but) when I climbed up a sort of ridiculous rock step thing, I was blown away by the 5spot performance.I would have bought it on the "spot" (ha!) if I had the coin.
3. Ibis ripley is the single fastest pedalling bike on smooth ST I have ever experienced. I feel like it almost accelerated out from under me. But it's too steep for me. With a big fork and an angle set, I might change my tune.
4.Troy. - It climbs up steep chunk weell, maybe better than my Tracer and it feels very lively. Too short of a ride to tell. I may ride that bike again as a friend is selling one and I am in the market.
VPP specifics:
1. Rear shock choice and set up makes or breaks the bike. It came with a RP23 HV shock and I could never get it "just right" and keep it there. It is/was extremely sensitive to pressure - like target +/- 3psi and it was either a pogo stick or would climb like garbage. I replaced it with an X-Fusion VPP tuned shock and forgot about wanting a different bike.
2. It's killer DH, especially after I ditched the Fox 32 for a for 34. Transformative.
3. This generation of VPP may (does?) suffer form small ring crap tastic pedalling. This only became painfully obvious when I went to a 1x10 with a 30t NW ring and Hope 40t cog. It simply pedals much better with a bigger ring up front. I think because it moves the chain forces away from the pivot thereby minimizing the torque effects.
4. Wide bars and short stem further improved the ride.
5. It's a very versatile frame with the option to choose travel between 5.5" AND 6". more than the change in travel, the change in frame angles between settings makes it really 2 bikes. You can build it light with a 140mm 32mm fork and run it in 5.5 "steep" mode, or you can run it burly with a 34/36 fork and run it in 6" "slack" mode. Depending on ride, I use both settings.
6. Climbing steep chunk, which I ride a lot, accentuates the VPP flaws however, the suspension bogs down when your CG points more toward the rear axle. This is a characteristic that DW seems NOT to have.
For #6 alone, my next bike will probably be a DW design - unless I get a killer deal on another VPP! Newer comparable bikes are coming with steeper ST and slackish HT, so #6 above combined with advances in VPP design might make it better.
Who knows....
Here's a follow up:
I did an extended ride on the Devinci troy, a split pivot 650b bike and here's what I thought:
It was super fast up hill, like way faster than my 26" intense tracer VPP bike. Super fun. DH was also fun. It's a fast bike through the chunder. I liked it so much that I thought I'd buy one as my next bike.
Then, a month later, I broke my intense frame. In a panic, and because i couldn't afford to switch to 650b, I bought a lightly used yeti Sb66 frame and moved all my 26" parts from the tracer frame.
Wow.
The yeti is heavier, longer and slacker than the tracer, but it absolutely rips up and down.... it pedals far better than the tracer did. So, I'd definitely throw switch into the mix. I don't give up much to guys on 650b bikes and the yetis kills it.
In fact, other than the "new it bike" feeling, I don't really want anything different.
The yeti does have a rockshox monarch debonair plus, which is probably the best rear shock made, so that helps.
I can't think of anything to upgrade, except maybe brakes? New dropper?
So, here by renaming this thread to:
VPP VS DW VS SP VS SWITCH
Sent from my SAMSUNG-SM-G900A using Tapatalk
