1 - 20 of 22 Posts
· Chillin the Most
Only complaints I've heard are to do with the bearings, they tend to wear fast and squeek alot. At least that's what I believe El Chingon said, maybe he will confirm this for me, but I'm pretty sure.
· Team Sanchez
Indeed. The VP Free climbs great, and descends even better, but the maintenance aspect on the pivots will drive you crazy. If you are deaf, you might be able to stand the creaking. Other than that, the bike is great! I sold mine after 12 months of use.
· Registered
The VP-Free does not have 'bad bearings' or bearing issues as some say.
However, like the RM-7 of old, the VP-Free requires that you regularly check the pivot bolts to make sure they are tight. I've had the pivots a little loose after a day of riding. If this is left unchecked, the excessive movement WILL destroy bearings in a hurry. If you do get the VP-Free (which is a great bike) keep in mind you will have to keep an eye on the pivots bolts to insure a smooth ride.
People might complain of 'maintenance' but 5min with an allen is nothing.
· Registered
yeah it creaks a bit
But I haven't had much problem with mine. I've found that regular (every 3 months) pivot maintenance has worked for me, and I ride in a lot of different conditions (dust, mud, puddles).
I also know that the Free is so fun, that the occasional creak is a small price to pay.
· Registered
1. Pivot maintenance is tedious. No matter how much you love your Free it is an undeniable truth that SC's vpp pivot junctions require maintenance. Your results may vary.
2. Long wheelbase. If you ride skinnes you might want to look elsewhere.
3. Pedal kickback. You will notice some of this when riding up semi-technical trails. Your bike is supposed to be on YOUR team, not working against you.
That said, I love my Free and have no plans to get rid of it.
· Lord of the Chainrings
I agree! If you overtighten the bolts, you get the creeking.
A 5mm wrench to a bolt every few rides isn't a maintenance issue, it's just common sense with any bike with pivots. If you don't want maintenance, buy a hardtail.
· Just another FOC'er
Mudd said:
I have on the Bullit, but not on either the VP-Free or Nomad...
I rode a Bullit for years and the feedback was pretty insane. The massive derailleur slap from chain growth when landing drops was pretty harsh too. It was still a fun bike though.
What is it with the VPP design and creaking? Is there higher bearing loads or do they just collect dirt easily? I wonder if Intense frames have the same issues. I haven't heard that, but then again there are a lot fewer VPX's out there.
· Hardtail Freak
Well, today my VP-Free started to creak a lot, pedaling on flat ground and a bit more while performing a standing climb. The pivots are pissing me off, especially the lower ones. If you look closely the axle on the lower pivots is open, and not 'closed' letting in dirt into the system.
I routinely remove my cranks and check if all pivots are tight, sure enough, the lower ones are loose.
· Registered
def. creaks and eats bearings, if you ride in the slop alot.
The b.b. was too high and the head angle was too steep for my taste.
I had alot of fun on that bike though... Def. a great climbing and descending bike, you can't argue that, just didn't suit my riding very well.
· Registered
My only complaint about this bike is the linkage behind the BB. It's a huge crud collector in anything but dessert conditions.The rear tire just drops stuff in there. I wish there was some type of fender thingy that could be attached back there.
That's exactly what I was thinking when I first got my Free!
Was thinking about fabricating a fender for it.
· Registered
If you come up with something let us know. I think I remember the older V-10's having a small fender for the rear wheel. Not too sure though. I'd bet it would increase the life of the 4 bearings in that area.
· Registered
wow... almost no one got any more technical than creaky bearings?
I have a few complaints:
1. Rides really high. It wouldn't be such a big deal if my BB was around what the vp-free's are listed on the site (14.8"). I measured mine at about 15.5", and paired with shock that's in the middle of the frame for a higher center of gravity... it's not good. Hard to whip through corners, or really lean it over.
2. Suspension progression? I've seen some progression charts of the vp-free travel. And since this bike is designed around a pedaling platform, yes, it was stiff at the top. Middle was very plush, and there was a small, short ramp up at the end. The bike is not real sensitive to small bumps unless you dial in more sag than it's designed to run (then it pedals more like a true DH bike..... not very well). And, it really blows through the travel on hard hits and is pretty harsh.
3. Sure, this bike pedals great, but if no matter how good it pedals, you're still pedaling a heavy bike with DH geometry up the mountain. Now, it can be set up to pedal well, but with a shorter fork (6" or so) and a light build. If you're going to set it up like that, then why would you need 8.5" in the rear? It'd be much more practical to get something like a nomad.
That said, i like the bike. I'd like something more pure DH because of how high the vp-free rides (i ride with two people on Sundays all the time... and the sunday corners like mad), and the fact that i don't do too much climbing. But i really think that SC needs to re-design the vp-free with a lower BB. There is a new movement of shorter travel DH race bikes (like commencial) that are light and pedal well. Not everyone wants a v10 because it's one heck of a bike (price wise too). I'd actually be very happy with this bike if the BB was 1"+ lower. A 15.5" BB is just pointlessly high.
1 - 20 of 22 Posts
