My VP Free frame appeared only about three weeks after being ordered. So much for a three month wait. Anyway, I put it together over the last few days and here's what I think.
I went for a 118mm bottom bracket even though SC recommends the 128mm w/ their etype adapter and an etype derailleur. I only want to run two rings (28/38) and figured I'd give it a shot with the derailleur I had. This was the hardest part of the setup. First an e13 DRS can't be rotated very far clockwise until it interferes with the suspension, so it is quite a bit lower than e13 recommends, but it is working ok. Also, when I setup the 28/38 rings, I had to use a bottom bracket spacer to keep the rings from interfering with the guide plates. The rest of the build went together fine, although I am somewhat interested to see how the rear thru axel drop out deal works out. I only have experience with the thru axels with pinch bolts, so this one relies on the axel bolts. If you torque them down on most hubs, the hub will start to drag. I temp-locktited the axel bolts to keep them from loosening up. One other note, my shop doesn't have the adapter required to face a rear 150x12, so I had to one-off one in the machine shop at my work, since I'm using hopes and want to face the thick paint off of the tabs on the frame.
Tuning the front derailleur was a challenge with all the travel... I still get the chain rubbing the bottom of the cage a little when the bike is completely un-sagged and in the small ring and the smaller half of the cassette... not ideal, but doesn't seem to affect normal operation on the trails. (I took the 5th off and cycled the suspension to check all the ring/cog combos).
Also, for those who want to build a Free into a long travel trail bike, you will still need a big fork on it. I'm using a 200mm 888 and my head angle seems to be slightly steeper than my roommate's 222/shiver, and the 888 has a considerably longer a-c than the shiver. After riding the Free with the 888 I really wouldn't go with anything shorter than 170mm travel. Super-T, 170 888, 200 888, Slider, 170 66, etc.... I think people who go with some of the 150mm single crowns out there will end up with some weird geometry, but I'd like to know how those turn out.
I'm happy with the way the bike turned out. The suspension does seem to pedal very well. I mean, you aren't going to win any XC races here... it's still 40+ lbs, but I am guessing I can still clean 95% or more of the stuff I generally climb on any of my other bikes. It will be a slow climber though. I think the 28/38 with 11-34 in the rear will do well, but I will have to give it some time...
Build:
VP Frame Large
200mm 888 w/ stem
CK Headset
Holzfeller Bars
Holzfeller Cranks 28/38
118/73e Bottom Bracket
e13 DRS
Hope Hubs on Atomic DHRs
Hope m4 200/180
Hope Seatpost QR
Maxxis Minion/High Roller both 2.5
Thomson Post
SDG Bel Air
XT Shifters/Derailleurs (med cage in rear)
XT 11-34 cassette
PC-69
Ourys
Shimano 647 Pedals
I will answer any questions I can if anyone has them... although, I want to get a few more rides on it before I give any real input to how well it works...
Thanks to Speedgoat (
www.speedgoat.com) for getting the frame out to me prepped and in a very short time. Thanks to Ben at UnrealCycles (
www.unrealcycles.com) for getting together the great wheelset.
