1 - 13 of 13 Posts
10,000,000 Watts
Discussion Starter · #3 ·
There was another thread awhile ago here with someone talking about it. I have one on my Levo in a (non-E) Fox 36. Easy install. Love it.
Cool, good to know. I’m excited to check it out. I’m 200# in my birthday suit, ordered a 50# spring. What are you running?
It does take a bit to set up. Be patient and get the tools now. They are not special, but things like a 22mm parktool spanner and such make it sooooo much easier. The important one is the flat face
socket.
  • Like
Reactions: Gutch
10,000,000 Watts
Discussion Starter · #7 ·
socket.
Correct, I’ve got the tools. Does look simple to install. Thanks y’all for the replies.
World Wide Cyclery tells me end of month. Not too bad.
I have mine on my YT Decoy with a Yari for that is really a Lyrik because I also upgraded the damper to the Charger 2.1
I purchased mine directly from Volsprung. In addition, if you have install or set up questions, give them a call.
On a tuning note, before I upgraded my damper to the Charger, I swapped the oil for the hydraulic bottom out to 10wt. The first part of my travel was pure bliss, but I always had to run it wide open. If I didn't, the last 30% of the travel was just too firm. This was mostly from the MC damper, but it's all I had to work with at the time. Swapping to a different oil allowed me to run 12 clicks on the H.B.O. for normal days, 6 on big hit days, and 16 (wide open) on those smoother, flow days.
  • Like
Reactions: Gutch
I just put one on my Bullit.
Went for a ride and it felt great and smooth, but unfortunately i had a crash in the beginning of that ride and dislocated and broke my shoulder (nothing to do with the smashpot, obviously), so it will be a while before i enjoy it again..... :(
10,000,000 Watts
Discussion Starter · #11 ·
Dang. That blows. Wishing you a speedy recovery!
1 - 13 of 13 Posts
