1 - 2 of 2 Posts
So my brother has a se flyer rigid 29 incher, to go along with our regular bikes. i feel like joining the fun.
i read the 69er sticky post wow there are some haters huh? stilll ive really liked the idea since ive first discovered it.
so i ran across they renolds steel voodoo for 170 bucks cad, a steal.
i was just looking for some opinions on a good rigid v brake fork? steel alum carbon? my brother nearly snapped his landing gear off. should i stick to steel?
also for my single speed cranks, i may throw on 8 speeds in the rear, but should i get shorter cranks like 165mm i see alot of singles are short (bmx, messanger fixie) like the bulletproof cranks from ebay. should i be looking at 165s instead of 175. i am 6'4"
crank length can be pretty preferential. *most* (not all) SS'ers will say go longer (180's) for more leverage. if you're used to riding 175's i'd say continue on with 175's...
probably a surly, salsa, or kona P2, 26" steel fork would be best to use w/29 front wheel for minimum A-C length, although you'd need to use a disc on the front. a surly KM fork (29-specific) has v-bosses, but has a really tall A-C and would upset your geometry a good bit.
1 - 2 of 2 Posts
