1 - 8 of 8 Posts
I got a 216x63 R2C Air MY 2016
The shock total length is 216mm, IFP pressure is correct but i cannot use full travel. There always around 3mm unused space above sag ring.
So i took of aircan, with the included bottom (4.5mm) out i can compress only for 58mm. Without bottom out its around 63mm.
Suggestions?
If you can strech shock its ifp needs to be pressurised to 250psi. Then the pressure will compress counter measure spring and you will get those few mm of stroke. If after pressurising it still lacks stroke it need full rebuild.
Discussion Starter · #4 ·
i even forgot that thread until i posted new one haha
the counter spring i think was no problem because the total length was 216mm
with unpressurized aircan and i would sit down with all my body weight, i couldnt get more than 60mm travel
not sure if it was overfilled
Discussion Starter · #6 ·
i measured close to 5mm thickness and 63mm travel would be with 0mm thickness which seems to be impossible
so air shaft protudes only 58mm with uncompressed bottom out
1 - 8 of 8 Posts
