Acquired this one recently:
Francois Mitterand era Vitus mountainbike frame. Glued alloy.
Bolted brake bosses, bolted cableguide. The black plastic in the monostay is a cover, not an elastomer
Bolted dropouts and cableguide
The mech cable are guided hidden under the downtube. Dirt is kept out by a removable cover
Not square, not round
The rear brake cable is guide through a slot in the toptube. One can also opt for an U-brake
No slot seatclamp. The seatpost is clamped by two parts moving to each other.
More French: Stronglight needle bearing headset
The Vitus is great for building a clean, minimalistic Vintage ride
Would like to learn more on Vitus bikes. Have already been told that this one is probably 91/92. Thought it was a bit older than bonded alloy Miyatas, but apparently it isn't. Is there a link with Alan?
