It's an Indy Fab. Do you even need to think about this? Keep both bikes. N+1 is always right.
High end 1991 bike is 29#? Seems heavy. 7 speed? So quite the mix and match. My 91 Kona is < 25 with suspension fork. Those answer forks are older than 91, really museum pieces now.Indy Fab all the way. I have a 2001 Fisher 29er that I love and use as a commuter but would consider replacing with an Indy Fab.
You did not mention wheel size, or if you've experienced any modern bikes with modern geometry. For actual riding I'd want modern stuff. A modestly priced thoroughly modern bike is far more fun to ride in trails and works better than the classic old bikes we have including Fat Chance where IF sort of came from.Hi All,
I currently have a 1991 Gary Fisher Mt. Tam with a hodge podge of 7spd components - mostly not original, and a series 1 or 2 answer manitou fork that needs rebuilding. It's built for urban commuting, which is it's primary use (think potholes and cracked pavement).
I now have an opportunity to buy a non-disc Independent Fabrication hardtail that has 9spd XT with a more modern marzocchi fork and a front disc for probably a couple hundred more than I'd get for selling the Fisher.
I know that at the time, the Mt. Tam was the most expensive hardtail Fisher sold ($1900!) and still 29lbs, but I'm wondering how much of an upgrade (if any) going to the IF. Primary use will be urban commuting, with the occasional trail ride.
Any suggestions about whether to keep the Fisher or move to the IF?
