Kenda Hellkat and Helldiver
Designed to meet the demands of World Cup racing, Kenda introduces a new breed of gravity tires, the Hellkat Pro and Helldiver Pro. Photo by UR Creative​
Remember the Kendal Nevegal? It ruled the roost of aggressive mtb tires a decade ago, very similar to the the Minion domination of today. Kenda has been reinvesting in this category for the last couple of year and they are clawing their way back to prominence.
They are doing it by attacking the aggressive part of the market, the downhill and Enduro categories. These areas require the highest levels of traction and sidewall protection and are synonymous with what Kenda was known for.
They have the rubber technology so they've invested R&D to deliver cornering and braking traction. And in this release, they are most proud of their sidewall technology. It's easy to make a durable 1500 gram tire but 1200 grams with excellent ride quality was the goal.
And since few people ride pure downhill, it's greatest benefit is as an R&D lab for the way normal riders want to ride, All Mountain and Enduro. Everything Kenda is learning on this iteration will be applied to All Mountain versions of this tire. So imagine under 1000 gram versions of these tires in they future.
Roger Hernandez talks about their latest tires.​
Features include:
  • Enhanced tread puncture and sidewall cut resistance
  • Low weight for wire bead downhill tire, with Hellkat Pro
  • Tubeless ready
  • Wire and folding bead options, with more constructions for enduro use in development
Technical Components of Advanced Gravity Casing
KVS - Kenda Vector Shield: Developed in joint cooperation between Kenda's North American and Taiwanese engineering teams at the Kenda America Technology Center. The KVS is a woven sheet of aramid fibers laid up across the sidewall of a tire which offers a light-weight casing shield with a claimed 285% higher cut resistance than standard protective materials. This allows for a reduction in the casing weight by up to 200 grams when compared to traditional 2-ply downhill casings.
Because of the addition of the Kenda Vector Shield, the casing now offers superior cut resistance, while being stiffer and lighter at the same time. As a result, you can ride with a lower tire pressure, which increases the tread grip without risking a flat tire. Additionally, the KVS material is claimed to make the sidewall stiffer ensuring better feedback for the rider and improved predictability in handling.
ICB - Iron Cloak Belt: Light weight aramid belt under the tread to increase the puncture resistance by 18%. This reduces penetration in the tread surface from foreign objects, punctures from rocks and other debris, and reducing the chance of casing fractures. As a result of the inclusion of ICB and lower tire pressures the tread can more easily conforms to the trail surface to provide better grip and low rolling resistance. The center knobs in the tread area, directly above the ICB, are more flexible and provide a better grip and fast rolling.
20mm Apex: A rigid rubber insert on the top of the bead that stiffens the sidewall of the tire and reduces chances of pinch flats or burps when run tubeless. The 20mm Apex is more than 60% taller than traditional apex inserts. Increased stiffness, fewer pinch flats or tires bottoming out on the rimwall, and the ability to ride at lower pressures equals improved control and grip when cornering. The added stiffness also helps translate feedback to the rider so they can tell what is happening at each contact point. This feedback allows the rider to know exactly how hard to push it before the tires break loose.
Kenda Hellkat Pro and Helldiver Pro
The Hellkat Pro and Helldiver Pro are, you guessed it, fast as hell.​
New Compound - RSR dual layer
Kenda has also developed a new compound for these new gravity tires - an evolution of the existing Race Stick-E Rubber (RSR) compound. Building on the original, the new RSR compound is a dual layer tread rubber, with the soft RSR compound on top and the stiff SRC on bottom. This new dual layer compound offers better performance because the stiff bottom SRC layer serves as the hard foundation for the softer RSR layer to push against. The result is a compound that provides better control and lasts longer than previous versions.
RSR
Kenda Hellkat
27.5x2.40 K1201 Hellkat, 60 TPI single-ply, Kevlar Sidewall inserts (black), Iron Cloak tread breaker, 20mm Apex, wire bead, CH2 chafer, RSR dual layer tread compound.​
Hellkat - fast rolling intermediate gravity tire
The Hellkat Pro is an all-new downhill racing tire, developed with professionals on the UR Team racing with decades of experience on the World Cup circuit. The Hellkat Pro is characterized by superior braking control and cornering traction, without sacrificing rolling resistance performance. Additional emphasis has been placed on the overall weight of the tire, the elimination of punctures and casing fractures, and construction all to yield the best results when run tubeless. The tread design is optimized for maximum performance characteristics across a wide range of conditions by balancing traction, handling and rolling speed. It has superior grip and slow rebound with super low rolling resistance because of the new dual layer tread rubber. The KVS increases cut resistance on sidewall, ICB a lightweight belt under the tread increases the puncture resistance.
Hellkat K1201- knob characteristics - tread blocks
Hellkat Tread Blocks
Hellkat K1201- knob characteristics - shoulder knob
Hellkat Shoulder Knob
Helldiver - versatile, fast & lightweight gravity tire for dry condition
Kenda Helldiver
27.5x2.40 K1202 Helldiver, 60 TPI single-ply, Kevlar Sidewall inserts (black), Iron Cloak tread breaker, 20mm Apex, Aramid (high modulus) folding bead, CH2 chafer, RSR dual layer tread compound.​
The Helldiver is a modern take on the fast rolling, dry condition gravity tire with aggressive side knobs. Versatile, quick, and lightweight with great grip when cornering. Developed in conjunction with Kenda engineering teams in Taiwan and North America along with cooperation with the UCI World Cup downhill racing UR Team. In development the key challenge was to make the tire fast rolling without sacrificing grip and braking traction.
This was accomplished with the use of the dual layer RSR compound and the siped center knobs that provided braking traction when needed and does not adversely affect rolling resistance. However, not every knob is siped because siping generally increases rolling resistance. The tread design is optimized for hard-pack race courses balancing the traction, handling and rolling speed requirements. It ́s as fast as a semi slick but with superior braking traction and cornering grip for its category.
Helldiver K1202- knob characteristics - tread blocks
Helldiver K1202 Knob Characteristics Tread Blocks
Helldiver K1202- knob characteristics - shoulder blocks
Helldiver K1202 Knob Characteristics Shoulder Blocks
This article is part of Mtbr's coverage of the 2017 Sea Otter Classic in Monterey, California. For more from Sea Otter CLICK HERE.
